Asked and answered in another post, just found the needed information.
I need to work on my research skills...
When I set the idle after the re-build and link & sync, which the idle was low; 650 rpms in neutral, so I bumped it up to 800 in neutral, in gear it drops back to 600 rpms, so do I want 800 rpms set up in gear or in neutral??? I will check the timing this afternoon, to make sure that I am setting on 18 btdc at full advance. Looking around locally for a igntion spark tester, for the 7/16" spark test...
