Re: Soaking Carb Help (with Picture)
If you are doing a rebuild, yes, you need to completely disassemble the carb. Remove everything that's removable except the throttle plate and shaft. The object is to get every passage squeaky clean. Otherwise you've accomplished very little. After soaking, blow out the passages with compressed air and reassemble with new carb kits. Make sure float level is set correctly. Before removing any pilot or mixture adjustment screws, count the turns it takes to lightly seat them. Record those settings so you can put them back in same position.
