Socket for the stern All-Around light
RobertM350
Hi, just got a 98 Key West 2020WA & cannot figure out what kind of all-around stern light they intended to plug into the socket. Is it proprietary? I searched online & in the stores, but I only find the universal fit style. Previous owner used a battery operated clamp on as a work around. This socket is 3/4" but has no notch for the universal light screws & instead of 2 pin, it looks like it has 2 contacts for a pole that would have a notch at the end making it a half circle with contacts on the flat part. I'm probably going to end up switching bases to the universal style if I can't figure it out. Not looking forward to that though, because the wire is JUST long enough coming out of the hole & there doesn't seem to be any other access to it & if I were to drop it....... Any thoughts would be appreciated. Thanks!
RobertM350
Re: Socket for the stern All-Around light
Nevermind, went to the KW dealer & got the current stock socket which is universal & installed it. Problem solved.
