Re: Solas Prop
To predict the result would be foolish on my part...each engine/boat/prop reacts different.<br />Larger diameter is usually better with higher mounting heigths due to more blade being "IN" the water as well.<br />Aluminum is much less aggresive and has less holding ability at higher demensions, so yes, the CORRECT SS prop will be much more efficient, BUT, it takes a bit of testing to find the prop that puts you at the top of the RPM range with the most speed.<br />The most important of the 2 is RPM being at the top of the range...the speed is only a result of how efficient the prop "is" at that RPM.<br />In rough water and tight turns, a trade-off must be made and trim must be lower to bite better in those conditions. The fastest set-up will blow-out in "slight" turns and rough water.<br />When I cruise at mid-range, I can expect ventilation in turns every time, but that's not a concern at cruise. At WOT, I never turn tight enough to make it vent so it's not an issue.<br />If you run the 17, expect slower speeds (Likely) even though the RPM may come up.<br />The testing with the Turbo was more than likely a 14-1/4" prop to be set up in the second hole..If the test would have been done with a Turbo Lightning, they could not have run the engine high enough without a jackplate.
