Solas prop
Bvask
I have a solas titan 4 ss prop 2553-141-19, came off evinrude, pressed in hub. Can I remove hub and get hub kit to fit my mercruiser alpha one?
Chris1956
The main difference between Mercruiser props and Evinrude V6 props is the length of the splines in the prop hub. The Evinrude are usually shorter. I was able to drill out about 1/2 the splines on a Mercruiser prop and use it on my Johnson V6 outboard.
You might try to fit the prop to the MerCruiser and see if you just need a different thrust hub.
If not, I would inquire at a prop shop to see if the hub can be swapped over.
