SKEETR
- Joined
- May 3, 2008
- 430
115 omc 1994 same as john/evin.
I'm looking in my oem manual at the starter solenoid. It is a 2d wiring schematic. At the starter solenoid am I looking at it from the rivited capped end nearest the terminals or...the other end? What did I do to my motor if I had it hooked up backwards? It seems to be mountable in one direction, capped end to carbs terminals out. I had the starter lead on the bottom, black, red/yellow, power, rotating upwards. Hep....
I was looking closely at the solenoid and at the small terminals one has a 'S' and the other printed w/ an 'I' .
switch/ignition???
