Re: Solenoid question
"Jumping in the sense used by mechanics and electricians means bypassing a switch or other electrical device by connecting two terminals with a short length of wire or other. So to jump the choke, you would connect the choke terminal to the battery terminal at the switch and listen for the click as the choke closes.
Your colors do confuse me a little because yellow and black usually ( on earlier Force engines ) is start, green is choke, and white and blue are stop circuit. Remind me: What year is your engine?
On the abck of the switch, if you look closely, it is labeled: "B" or bat. Is red and is battery power. two terminals are marked "M" and are the stop circuit. A white wire connect to one and a blue to the other. "S" is start, "C" is choke, and "I" is ignition, sometimes called "A" for accesory. It only has power when the switch is in run position and is used to power things you only want on when the engine is running, like gauges.
