diesel1960
- Joined
- Jul 3, 2012
- 205
Anybody knows how to calibrate acceleration pumps on Solex 44 PAI downdraft carbs. ?
You'll have to adjust the nuts on the accel pump linkage so that they all start to compress the diaphram at the same time and also at just the right time. It can go either way as to when you want them to start squirting and you'll need to experiment. I start out with them starting to squirt as soon as you begin to open the butterflies. You may need to have them begin compressing the diaphram just a tiny bit later depending on how the engine reacts. I've had to play with them to get it right.
Another thing to look at is the position of the spring in the housing. I've seen a drawing in an aftrmarket kit that shows the spring on the lever side of the diaphram. It's supposed to be in the carb housing so that the lever pushes against the spring and compresses the diaphram to push fuel up into the candy cane. The spring then pushes the diahram back.
in the Seloc manual,drawing is wrong ,photo is right.
Sounds like you may have the wrong manual. Try this OEM manual and see if it helps (pages 32 and 33 of the manual)
http://www.4shared.com/file/59747156/6c065c44/AQ130_thru_170_Serv_Man.html
