I need to replace my 61" inch wide axle for my Noreaster trailer that holds my 15' Boston Whaler boat. The parts guy told me a hollow axle is better because it can drain the water through the drain holes. He also said if the solid axle is bent or warped it can cause trailing problem but he admited that less likely. With either axle I need to wash the salt water off.
I went ahead and purchased a galvanized hollow axle since conveniently thats all he sells. I am having second thoughts now. What is more durable and lasts better. I only use the trailer twice a year.
