I was not getting any water flow from the tell tale.
Replaced impeller and still nothing from tell tale except a puff of exhaust .
With the LU off I put a garden hose on the copper tube and initially there was no sign of water flow but after a minute there was good water flow from the tell tale. Im a bit concerned over the initial lack of water flow though. It seems like you have to pump in quite a bit of water just to get the tell tale to spit.
I also notice a small amount of water coming from the water jacket gasket by the top cylinder. Not much. Just a trickle.
Would the leaking water jacket cause the water pump to not pull? I will replace that gasket eventually but would rather wait unless its causing the lack of water flow. I dont want to be snapping off those bolts causing more headaches.
As the next step I plan on replacing the entire water pump and seeing if that gets things moving but would appreciate any other advice.
Compression is right at 105 on all 3 cylinders if that helps at all.
