Borgey401
- Joined
- Jun 11, 2011
- 155
I have a 1991 Johnson 25 HP model # J25ELEID. I am pretty sure I should be getting more power out of this motor then I am as of right now. It's on a 15 foot West Wind Aerodyne and I am only getting about 20 MPH out of her if I'm lucky. I'm having the carb cleaned out and rebuilt tomorrow but I wanted to check it she was firing on both cyclinders before I did that. So I just went outside and started her up. I pulled the wire off the spark plug on the top cylinder and she still ran. Obviously she didn't run all that great with it off but it did not stall. Then I put the top wire back on the plug and took off the bottom wire. She then started to putter more then the when the top was off and after about 30 seconds or so stalled out. It would without a doubt run when only the top spark plug wire was plugged in but did not seem to perform as good as the other cylinder. Is this something I should be worried about? Any suggestions as what to do next (if anything)? Like I said I am getting the Carb cleaned tomrrow (was also thinking maybe the high speed jet was clogged up). I basically just want to have a healthy motor like everybody else would want! Thanks for the help in advance everybody! This forum is absolutely AWESOME!
