My temperature wont rise past 105 when on the water. I checked the gauge, its working fine-- I think the sensor is also working fine. Thermostat was recently "serviced/reseated" by mechanics so Im thinking they either installed it wrong or completely removed it. Can anyone point out where it is on the engine? Im thinking I need to remove the 4 hoses marked with blue dots and then undo the two bolts holding the piece marked with the green dot. It should be under that, right?<br /><br />I ordered a service manual couple days ago, hasnt gotten here yet. I ordered a temp gun, which I got yesterday but figured Id check this before getting back on the water w/ the gun. Let me know if you guys think I should just wait for the manual.<br /><br />Also, will a regular 160degree car thermostat + gasket work?<br /><br />
