Let me start out by saying that I have not worked on many 4 srokes and not much of a history with Yamaha.
A little history on this engine
1989 4 stroke 9.9
Owner has had trouble with the engine starting and stalling for quite a while and had taken it to several repair shops and one dealer. No one was able to help him out with his problem and I said I would try to find out his problem.
You could pump the primer bulb until firm and the engine would start and run until the carb ran dry. I was thinking fuel pump but it would not stay running by pumping the primer bulb. Took the carb off and tried blowing into the fuel inlet and it would not pass air.
Replaced the needle valve and the engine will start and idle great on the hose.
Put the boat in the water to test it under load, will start and idle in gear great. When you try and apply power the engine will stall, it will restart without any problem and idle great.
If you restrict the air flow by holding your hand over about 1/2 of the air intake the engine will acceralate properly and run at high speed without any problems.
I am not sure of the float setting as the carb has been apart several times by other people. Could any one give me the correct float settings?
Anyone have any ideas that might help me out?
Sorry for the long post, just trying to give you the whole story.
1989 4 stroke 9.9
