captainron19
- Joined
- Feb 10, 2012
- 54
Single outboard and putting in a 4 position battery switch. Having boat repowered next week so thought this would be a good time to get the switch in before going for the motor to be installed.
Couple of questions...
1. According to the diagram I need to run a jumper cable between my negatives of both batteries. I bout some 4 gauge black cable and the metal hubs to put on each end to go to the negative terminals...... I'm not sure how they connect since I cant tell if they can be crimped or not..... is soldering them in place ok?
2. Gonna use 1 position of switch for outboard obviously and another for all my electronics. I already have a positive feed coming from one battery to my console for all of my power along with a ground wire going to same battery. Where should that main ground wire go now? Also...I have a couple of items directly wired onto the battery terminal (transom bilge and main bilge pumps)..... can I just wire them directly to the switch or do I have to run them back to my console where the rest of my hot leads are? Also, those 2 pumps have ground directly onto the battery, can I still ground them on the battery neg terminal?
