Re: Some gas in exhaust, an intermittant miss
maybe start with checking and cleaning the grounds, even though they might look fine, its very problematic when they are corroded, cols,paower pack, etc, look for any loose connections, you carbs .maybe a little piece of trash is floating around, and getting stuck in the jetting or venturi, you didnt mention anything about filter changes, hoses tend to break down with different fuels being run through them, i have also seen high speed nozzles broken or gone causing a hesitation due to to much fuek entering the chambers, pop the air box and look into each carb, like 5 minute check<br />its a start good luck, keep us informed
