Yep, I decided to save this motor unstead to neglict what needs to be changed.
-Starter rebuilt in a starter/alternator shop, ok this is simple to re-install.
-While the starter off, the carburetor is very easy to remove so I have a new carb kit + a new BRP float for it, are they tricky carbs. I have re-built much smaller outboards carbs but I don,t know if it's different for a bigger outboard.
-While I was a bit disapointed for the compression test #'s at the end of season, I have got a new head gasket set (there are 2). The motor overheated a bit last year when I changed the impeller and the water tubes were not propper in the pump grommets. While I'm waiting for my book, does someone here as the torque specs for the head screws? so I could maybe look at this this weekend.
-New lower unit seals, Sierra kit. This is the most scary part since it's an electric shift. The gears oil was a bit milky and I've replaced before the 2 washers. Is this a complicated job to do with special tools or it's easy? Like I said, I have a factory service manual coming soon.
Thanks for helping!
Thanks for helping!
