recently i aquired a 7.5 1980 ac lightening,upon testing it i found the tell tale to be spouting very hot water, upon advice (from here) i have changed the gaskets on the water jacket (tell tale exit block).and checked the thermometer ,now its not pumping at all, i have checked for blockages and none are found, what i have found however is that if i blow down the tell tale whilst the engine is in a bucket only a few bubbles show,however if i blow down the tell tale and cover the exhaust hole on the leg the ammount of bubbles increases,
which means in my crazy thoughts that somewhere exhaust is getting in with water and as the pressure from the exhaust is more that the water pressure,the exhaust wins.
some one please help me get this baby pumping water as it should again
