I have a 1990 120hp force outboard on my bayliner. I have some questions for you guys....
1. I damaged my prop on some moss covered rocks so I need to replace it and have found the identical sized prop/splines on ebay. Do I need anything else or just the prop? It is a mercury prop made by Michigan and is stainless. A flow-tho hub kit perhaps??
2. When on WOT the boat sometimes will bog out. I found that by cleaning the black plug connectors behind the coils for each one the engine will be fine again and run great until it happens again. They seem to have a bad connection there and are arcing. They are a male/female pin connector. I would like to replace these with something compatible. Any ideas? They must be low voltage as they are not thick wires.
3. The tilt is not staying up and slowly drifts back down. The fluid levels are correct. I read somewhere that you have to replace the o-rings in the pump by removing the allen head bolt? There is a ball bearing behind the bolt?
Thanks in advance!
Thanks in advance!
