somebody has to have the answer
bamboo17
have water pouring out of pivot area where shift linkage and steering linkage go in , water ooozing out of that opening???? some one please help
pnwboat
Re: somebody has to have the answer
That's a tough one. I'll give it a shot. Sounds like there is a leak between the block and the driveshaft housing??? Look at the following diagram.
Water is pumped up the water tube (#5) and looks to be attached to the exhaust tube (#6) with items 1 - 4. Item #4 is a rubber seal. There is a gasket (#8) between the exhaust tube and the lower plate (#9). The block is probably bolted directly to the lower plate. I suspect that there is some type of RTV silicone sealer between the lower plate and engine block.
Problem may be seal #4, gasket #8 or seal between the block and lower plate. Could also be cracked lower plate, maybe crack in lower part of the block. Then again, it may not be any of the above mentioned areas. Just some ideas. Hope that helps. Maybe someone else can chime in.
http://www.crowleymarine.com/mercury_parts/1696/16.cfm
pnwboat
You have a better chance of getting ideas/answers if you post questions on the public forum. Two heads are better than one. Sent you a PM (Private Message).:)
bamboo17
come on anybody had a problem like this?????
