Re: Someone Please help I am in need of 3.0 block
Can't beat the price of a new motor. $1999 plus shipping.
And in your application since pre 90, you will need a 12.75 flywheel, new engine coupler, plus dist. (new $100). I went this route 2 years ago. This engine does not come with the manifold/carb. You reuse your old manifold/carb. If you have a large ports on your manifold you will need a special gasket(no big deal). This engine comes with water pump, valve cover, oil filter, oil pan.
Also I had to rejet my carb. because it was burning too rich with the new motor. I had 50/51 jets, I thought this was odd, but once I rejeted the carb the plugs burn nice and clean.
I bought mine from Michigan Motorz.
The only thing that happened to me is the bolts that bolt the flywheel on where a few thousands to thick and I had to grind a few thousands off the bolt heads so they did not hit the bell housing. This caused me to pull the motor back out of the boat because I had a noise and it ended up being the bolt heads that bolt the flywheel on. I ground a few thousands off the bolt heads and all has been great since then. I run in salt water so I have antifreeze in the engine block. Now have 140 hrs on the motor and it does not burn a drop of oil.
