I have a chance to get a 1969 Johnson 100hp outboard for a reasonable price from a relative. The motor hasn't been run in 24 years, (since the death of the original owner), and it was fogged with oil when it was put up. The plugs were removed and oil sprayed in the cylinders, with the spark plugs put back in finger tight, covered and kept inside a garage. I unscrewed the spark plugs and turned the motor over by hand. It turns freely, and I can't feel any tight spots. <br /><br />I don't think that this motor ever had a lot of use. The paint under the cover looks like it just came off the show room floor. Heck it even has most of the paint on the prop. I am pretty sure the motor is in good mechanical condition.<br /><br />I guess my question is. What is the reputation of this motor? Was it a good reliable motor, or was it a lemon? I don't mind putting some work/money into it, if they were good motors, but if they were dogs, I'll pass. The motor will be used in a displacement hull workboat, probably at ½ throttle or less, as a lot of speed isn't possible.
