Texasmark
- Joined
- Dec 20, 2005
- 14,893
I was out with my sweetie today and observed a couple of things. Some guys on here talk about engine torque falling off when you get out of the recommended rpm range. I didn't know one way or the other.
So, today I disproved the myth. I have this thread and a similar related thread in the prop section and they are related. Just so happens this is related to engine torque above rated rpm range and the other has to do with prop performance.
So, on engine torque above the recommended rpm range, which for my engine is a 5500 upper limit:
I usually run a 24XP Ballistic prop on the engine in the attachment.....sorry for the side view but I couldn't find out how to rotate it up right and I am retired and tired of having to think. Forgive me!
That prop runs my little boat at 5700 rpms right at 50 mph. Bam prop slip calculator says that 5700 rpms with a 24P prop with a 2.33 gear box at 50 mph results in an 11% slip. That's a good number for a light boat with a stepped hull....see Avatar.
So I take the 24 XP off and install a Ballistic 21P....both props shown in the prop thread. Today I took some data:
I cut the throttle back to a reasonable rpm and running at 40 my rpms were 5800. Running the BAM prop slip again that's a whopping 20% slip. But the point here is that the engine is still putting out ponies.
So I firewall the throttle and the rpms go up to 6600. My little Merc just loves it. Purrs like a kitten. Every time I firewalled it the little darlin just said "yes sir HP at your command". Back to the story. At 6600 I am running 47.5mph. BAM prop slip calculator says slip is now 15%.
The slip in my opinion is due to the hull efficiency. The point here is that the engine continued to put out HP at the increased rpms, and took the additional rpms, and did it at a 145 vs 138 loss ratio meaning that it was more efficient at the 6600 rpms than it was at the 5800 rpms.
So sirs, if your engine craps out when you "give her the reins" maybe you need to invest in a Mercury.
My humble 2c and worth every penny you paid for it.
Mark
Mark
