Got a 1991 Evinrude on a Grumman fishing boat.
Runs good, but when I got it in the water my idle was 1500 RPM.
I just got a shop manual and a parts manual for it last week from Ebay, so it was reading and plan of attack time until I could get to it, (it's 220 miles away from me at Clayton N.Y).
I figured I'd check all the alignment marks up, check the idle mixtures, even them out, turn the idle screw a turn or 2 and go play!
What I found was the engine timing marks are all golden, but the high speed cable was all but 3 turns turned out, as well as the idle speed screw turned all the way in????????????
The cam wasn't hitting the idle speed screw until I used up the last 3 turns.
The mixture screws were all even- 1 1/12 out
Someone had the carbs off, as they were marked.
The cams on the carbs although close were a tiny bit different.
Also you could see rust marks where the screw had been before on those cams. The screw wasn't in that same location?????????
I got the idle to 900 by taking the last 3 turns out of the cable and went to go play.
(I figured it's running, time is getting short, I'll attack it when I hauled it home for the winter).
I THINK the cams on the carbs are the problem, I THINK if I sync the carbs up (I use the drill bit in the throttle blades method like I do on my BMW dual carb bike- Turn the throttle and lock it to a drill bit size-the other ones should open the same size bit).
Then perhaps take the cable off and back the idle speed screw down and set the linkages so it idles @ 700 er so, and then adjust the idle speed screw, and finally the cable.
At least that's my plan...
Thoughts?
Ideas?
Joe
Thoughts?
Ideas?
Joe
