Something is Rattling! :-(
mattfish11
Ok first off, this is a mid-size Mercury 40HP 2 stroke.
The past couple times out I've noticed a faint rattle or ringing of my motor at idle. It immediately stops when I put the motor in gear and doesn't recur until I'm back in idle.
I've narrowed it down to the lower unit and noticed there's some play in there, a tiny bit of play between the spline of the lower unit and the prop housing. I've also noticed a tiny bit of play in the shaft of the spline as it goes into the lower unit.
I'm assuming this should looked at by a professional? Is there anything you guys can think of that might be a quick fix (like - duh! should have thought of that). I've tightened the prop down good - and that doesn't eliminate the problem.
Any help here?!?
Thanks!
Matt
Wingedwheel
Re: Something is Rattling! :-(
What does your LU lube look like? Can you see metal flakes in it?
mattfish11
LU oil looks clean. Not milky, no metal flakes. Just replaced the oil. Hmmm.. guess I'm off to the mechanic, again.
