wecoyote
- Joined
- Apr 25, 2008
- 19
Up to now...
Water in oil.
Put it on the hose, and water in cylinders.
Yesterday....
One bolt missing in joint from manifold to riser. Assuming that could cause a leak and deterioration of the gasket thereby latting water into the exhaust.
Removed riser, and not to surprised to find gasket crumbs. Was surprised to look into riser and find a nickel sized hole almost half way around the arc of the riser into the cooling passage. Not a crack but a hole.
Any ideas how that happened?
On a lighter note, I removed the t-stat and poured water into the manifold cooling passage until full to the mating point of the riser, and it held it for 30 minutes while I put the tools away. Can this be good news?
Water in oil.
Yesterday....
