somewhere
El Capt Hook
yes some where I seen a sight where a person took a lawnmower motor and put it on the outboard lower drive unit anyone se this .if so Where can I find it thank you Ron
JB
Re: somewhere
Outboard Non-repair topic.
TOHATSU GURU
Re: somewhere
Also Clinton and Eska. Tanaka used a weedeater engine. None of them ever inspired confidence. The only one in production today, other than the B&S, is the Go-Devil(uses Honda, Kohler and B&S engines). Also, there are some weird ones used in Asia that are locally produced.
El Capt Hook
Re: somewhere
thank you the one I seen was a b&s lawn mower motor mounted on a eska out board drive unit. but can't remember where I seen it .(crs) Ron
timmathis
Re: somewhere
See it is here at iboats. That goes to show you check with iboats first for anything! Tim
El Capt Hook
Re: somewhere
Originally posted by El Capt Hook:<br /> thank you the one I seen was a b&s lawn mower motor mounted on a eska out board drive unit. but can't remember where I seen it .(crs) Ron
this was homemade one the same motor thats on your lawnmower .and yes this is one of the better sites on the web I think thank you El Capt Hook
rodbolt
Re: somewhere
had a friend mounted a 5HP lawnmower on an old 18hp ev frame. moisy as stink but it pushed his tub about. was acutally rather cool<br />no water pumps to burn up and a hot exhaust :) . go Devils are rather cool as well
