terrymiller1973
- Joined
- May 11, 2010
- 13
I had posted my questions in the Yamaha and Suzuki forum prior to seeing this one so please forgive me if this is acceptable. Sorry about the edit guess to early in the morning now for the question. My WOT is 4600 I have read that it should be around 5500 is this correct, if so what prop should I try to get me close to this. Some other symptoms are that once the boat comes off WOT it start to squat in the water badly like it is trying to plane out again no matter how I trim it. The only way to get rid of the squatting is to use way to much trim tab to force the bow down some.
1990 238 Pro line WA, 8'6" beam
1990 Yamaha etld 200 on a 2' Gil bracket
weight fully loaded 7000
fuel 100 gallon
wot 32mph @ 4600 gps checked
22mph @ 3600
current prop says 19-M, 3 blade aluminum
could not check if the cavitation plate is above the hull or not due to being in the water currently.
any other needed information I will be glad to try and answer if I know it.
fuel 100 gallon
22mph @ 3600
