sound like it is missing 85 -85 outboard
nottuskram
Hello
When I start it up it runs fine.I go to put it in gear and it stops running.I let it warm up(15 min) or longer an it well finally go.When it is going it sounds like it is missing an after a while it well clear up and run fine
maxum247
Re: sound like it is missing 85 -85 outboard
I know this is an old thread but try decarbing the engine and putting in new spark plugs afterwards.
gjm
Also, when shifting into gear, do it quickly.
nottuskram
thanks for the info.What do you mean decarbing the engine.
Thanks Mark
maxum247
The pistons get carbon built up on them and the sparkplugs tend to fowl causing the engine to not want to idle well, Force is known for this. Pick up a can of Quicksilver Powertune Engine Cleaner at your local Mercury dealer and follow the directions on the can. But before you do that use the search button at the top of the forum page and type Force engine decarb and read up on the subject!
Replace the original sparkplugs after decarbing the engine with new one's as decarbing fowls the originals.
