Source for pole light bases
infx708
The wires running to the pins in my pole light bases are shot. I guess my options are to replace the entire base, the pin, or the socket. I'm not having any luck finding a matching base, nor one big enough to cover the existing holes. Does anyone know of a place that will sell just the socket part that I can stick into my existing base hardware?
DrCox
Re: Source for pole light bases
Have you tried EBAY or CRAIGSLIST? There are a ton of people parting out boats.
I have already ordered parts for an '88 bayliner from those 2.
-DrCox
salty87
perko probably makes the base. have you looked through the store here? i found this one real quick, not sure what you need...
http://www.iboats.com/Perko_Pole_Li...21054053--**********.035148644--view_id.39364
perko's site may show the one you want
Mark42
Here is an idea....
If you can't find a new base big enough to cover the old hole, then cut a piece of 1/4" plexy large enough to cover the hole and be screwed on around the parimeter. Cut a hole in the plexy for the new smaller base. Sand the edges of the plexy smooth, should have a nice satin finish. Paint the bottom side of the plexy black or while or a matching color to the boat and install the plexy and new base.
The painted bottom will look nice through the clear plexy, and the new base will be properly fitted.
erikgreen
I dunno if you're near a Northern Tool and Equipment, but they're having a sale ATM... clearing out their boat stuff. I picked up one of these bases for about $4.
Look around, they're a pretty common, standard item.
Erik
