Re: SP-A Shift Mechanism Sealing Ring
Hi there, how did you try and seat the seal ring? Volvo tool 884793 would make things much easier on you to do it right, though I haven't tried as i'm by the book as much as possible, I would imagine you would be able to find something like a socket of the same diameter to fit the seal to help seat the seal. Is the area where the seal rides and lays clean, corrosion free, WELL lubed to help seat the seal?
Is the seals steel edge facing inward?
Tool 3856761 is to help with the shimming process of the center screw. A very important step in making sure this particular job is done correctly.
With Volvo stern drives of this nature, it is very important that any type of rebuilds big or small is done to specifications or it could lead to major failures.
The importance of Volvo shimming is best described by both Don and Muc in the thread below starting with post number 8 if interested.
http://forums.iboats.com/volvo-pent...rive-shaft-help-don-s-582857.html#post4013860
It appears you are using a Volvo service manual? If not, page 71 should help guide you along.
http://l-36.com/manuals9/Volvo_Penta_Workshop_Manual.pdf
Hope this helps some, good luck.
