Spaghetti Seal Install - '61 Evinrude Lark 40 HP
gbeardmore
Being a novice with Clutch Dog and FWD Gear problems I was lucky enough to find a guy locally that could help me replace these items with parts from a "parts motor" I picked up. He got everything swapped out and the motor runs fine now with no slipping. GREAT!
But when we put it back together he didn't seem at all concerned about installing a (missing) Lower to Upper Gearcase Seal (spaghetti seal). So of course, after running it for 2 tanks of gas worth, when I checked, about 3-4 tablespoons worth of water ran out before any oil drained.
My question is: Can I simply loosen the 2 halves and press the seal in, being sure the 2 ends butt up good and close? My repair guy was nice enough to come over to the house to fix it, and wouldn't take a penny for his time. So I hesitate to call him back to tear it all apart if I can just do what I've described.
Any thoughts?
Thanks
lindy46
Re: Spaghetti Seal Install - '61 Evinrude Lark 40 HP
Yes, that seal must be in there. I usually put some Permatex form-a-gasket sealant on as well. Gives a good water-tight seal.
F_R
You should be all set on this. I answered your question and posted the instructions on Ax-A-Member
