spare tire
zach103
how do i get the right spare tire.. do i use the same dimensions on the tire i have now. or what?
kenmyfam
Re: spare tire
Make certain it is a trailer rated tire though.
Not a car tire equivalent.
Philthyphil
Re: spare tire
Along with the tire you need the proper wheel size, and esp bolt pattern. Does not hurt to have a spare set of wheel bearings with you and put some bearing buddies on your wheels and grease them often.
zach103
Re: spare tire
the trailers like 2 years old a nice ez loader that has the buddies..
why wouldnt you use a car tire equvilent? just wondering
srothfuss
Re: spare tire
Trailer Tires have been designed to handle trailer loads.
Car tires were designed to handle car loads.
Two totally different loads and handling chacteristics.
A spare tire is a great idea. What tires are on your trailer now? That's the size you should get as your replacement.
zach103
Re: spare tire
im not sure at the moment all i know is 5 lug i think good year but im not sure of the specs.. the boats not at my house so ill try and get them soon
zach103
Re: spare tire
couldnt i use one of those small car jacks. or is something different
Pony
Re: spare tire
That depends on the trailer........I have had problems getting a car jack to go high enough.
Personally I use a bottle jack that I keep under my back seat along with a 2x6 for a flat surface. I keep a jack stand back there as well.........
tashasdaddy
Re: spare tire
when a trailer tire goes flat, there is not a lot of room under the axle, to get a jack. let the air out of one and see what i mean.
woosterken
Re: spare tire
take a hunk of 4x4 and cut the end at an angle,pull the flat up on it it will raise the axle high enough to get the jack under it.
woosterken
Philthyphil
Re: spare tire
I'm with Pony, I keep a small bottle jack and a few chunks of 2 by 6 with me when I take the boat to the cottage for the summer. Probably because I only tow twice a year I make a big deal out of it, extra everything, but it is a four hour trip and I have lots of time to prepare for it. Also I bring a large breaker bar with extension and proper six point socket for the bolts. It doesnt matter what your doing if you bring spares and are prepared to use them, seems you never need to!!
zach103
Re: spare tire
the tires are Goodyear st185/80r13
anyone know where i can get these cheap?
NSBCraig
Re: spare tire
Yeah sure is cool knowing your stuff is in order and your ready to deal with whatever comes at you.
Ram58
Re: spare tire
You can probably get that tire from any Goodyear dealer, but will pay the price for it. Unless you just want everything to match, any spare tire of the same size will work. Most people only use a spare long enough to get their original repaired and put back on. I just put a new set of radials on my trailer the same size as yours and they range anywhere from $60 - $100 each.
NCCamper
Re: spare tire
I've had success with kmttrailer.com. They've got wheels and tires for our boat trailers, and prices, even with shipping included, cannot be beat.
NCC
