Spark advance 1977 Ford Marine 175 hp 302 Engine
RogerBoat
I am proud to say I completely replaced all the ignition parts, set timing to 10 Degrees per Seloc manual and boat is running better than ever.
I am not so proud to find out I didn't know there is a difference between "initial timing" and "total advance timing"and that total advance is the more important setting to get right. 2 hours on internet did me no good. So I am looking to you expert folks to set me straight.
I am using Seloc Manual. It says "Timing marks Degree" should be 10 Degrees (BTDC) which I presume for idle RPM.
Then it has an abbreviation "MFD." which states .25-.28. What is that....is that what "total advance timing" should be? If so, what engine rpm should this take place? I presume this is degrees BTDC and takes place before 3000 rpm , at least that is the rpm I usually cruse at.
As usual, I am wrapped up in fine details and probably want to hear that setting the engine at idle (600 rpm) is enough and forget all the rest. What do you think?
RogerBoat
Well!!! Thanks Supreme Mariner Alldoge,
I realized how dumb my question about MFD was as soon as I released the message...didn't visually take note that the values were fractions. To my credit, I only saw 25-28 which happens to be the values on the seloc graph for rpm's above 3500.
I wish I had understood what MFD meant when I was struggling with finding the right condenser. Would have saved me a lot of time.
But now about your chart....
It says, "add value to basic Timing setting for total advance." If I understand your information correctly: I should set at idle, to 10- 13 degrees (Before Top Dead Center) then take the value for 4000 RPM (about 24 degrees) add them together for a range of 34 - 37 degrees? Then take the RPM up to 4000 and expect to read a range of 34 - 37 on the flywheel?
Sorry I am having a hard time understanding this...Seloc manual agrees with 10 degrees at idle but the graph only suggests I should read 27 Degrees at 4000 RPM.
Appreciate if you can set me straight about this.
No
Timing is set at 10 BTDC and the distributor will provide additional advance between 10 to 13 degrees.
Total advance = 20 to 23 degrees
The 3 degree difference is based on the spring tension on the flyweights inside the distributor
RogerBoat
Gotch ya....Thanks...Total Advance 20 - 23 Degrees. I probably knew all this 25 - 30 years ago when mechanically tuning engines was a must...Now at age 76, I have forgotten. It may be time to sell this 43 year old boat before I have to fix something else. But the problem is....there aren't many parts left that are more than 4 years old and I can't find another boat I like better.
