The screw that controls the timing spark advance doesn't appear to be working. Motor is a 55HP Env. 79' model. Turning the screw clockwise or anitclockwise does nothing to the timing. Using a strobe light indicates that there is no movement whatsoever. After re-cleaning my carbs, I hadn't checked the timing BEFORE going out, but timing was ok before carb clean. Yesterday the engine was at it's worst it's ever been, in fact I got towed in because it eventually died after cranking it about 60-70 times. I decided to check the timing when I got back home and it was out by about 3 degrees. Now I can't adjust it. It was a bad day...
