Platypus E65
- Joined
- Mar 30, 2010
- 57
Recently while running the motor WOT it started to run on one cylinder, checking to see which spark plug failed I found that the top spark plug had broken in half around the insulator. Installed a new plug, started up the motor fine, planed the boat up to WOT and the plug started misfiring after a minute or so. This time I found a tear on the cap above the terminal of the plug. Taped it with electrical tape, once again the motor started up fine and on the way home the plug started misfiring again after a minute at WOT. At home I switched the spark plug wire and caps with a used one with no difference, starts up fine, revs up to WOT then dies after a minute of running.
What would be causing the plug to misfire or die after a minute of running fine?
How do I diagnose this?
TIA
TIA
