Spark Lever Advance Sticker 84 100hp E100WTLCRS
edfishing2
100_2280.jpgI got some carb cleaner on the little sticker on the spark advance lever that shows the timing max advance and you can't read the number.
Does anyone know what the correct number is or where to get a replacement this sticker?
emdsapmgr
Re: Spark Lever Advance Sticker 84 100hp E100WTLCRS
Likely you can also get the information you need by calling the Bombardier consumer hotline at: 1-847-689-7090. I believe the W in your model number indicates this is a commerical engine. It would not be unusual for the timing on this engine to be different from the normal consumer V4 engines.
