Wetwilly62
- Joined
- Aug 12, 2018
- 50
What's wrong with it? Was it running ok? Looks like deposits that were burned off during that high speed run.
Or carbon deposits that flaked off inside the cylinder. Had you been running any kind of engine cleaner through it? Put in a new plug and see what happens.
I would spray a couple of cans of Engine Tuner, or Merc Power Tune through the engine. What oil are you using, and at what ratio?
Seafoamed it two months ago, new plugs since then. Coils replaced prior to this run , much improved. Can a power pack cause weak spark on one cylinder or both ?
Spark was tested at 7/16" some time ago.-----Motor is still displaying unhappiness after 2 new coils were installed.
