New to the forum...thanks for the help. My head hurts from what I thought would be a simple plug change.
I have a 19' Wellcraft with the original 115 Johnson. I can't figure out which Champion plug to use. The engine plate says 1996. However, the serial number is JX115HLEUA which means it's a 1997 right (E = 9 & U = 7)? I'm assuming it's a 1997 model that was out of the factory in 1996.
Anyway beyond that I don't know if it's a 60 or 90 which would be the difference between a QL78YC and a QL82C (I think).
And then on top of that, the local boat stores carry a Champion L78YC is this the same plug as the QL78YC or do I need to order some QL78YC or the
QL82C in order to get some extra shielding (I don't know just guessing at this point)?
Bottom line, I NEED to go fishing before I go back to work on Monday. Please help.
Tight lines,
Phil
Tight lines,
Phil
