navigator336
- Joined
- Jul 27, 2003
- 270
My boat has 350 vortec engines with EST ignition and is carbureted. The manual says to gap the plugs at .030", while the TBI and full injected versions, using the same ignition system are gapped at .045". I called the factory and they confirmed this is correct, but the tech couldn't explain why other than, "the engineers say so". I'm guessing that the fuel to air mixture is a little richer with carbs and that slows the ionization of the air in the spark plug gap thus making it harder for the spark to jump the gap. Is this true or is there another reason? Also, does changing the plug gap by .015" effect ignition timing? If it does, I would assume it advances it. And finally, is a timing light triggered by the rise in voltage in the plug wire as it builds awaiting the gap jump, or when the plug actually begins it's fire? I know we're talking fractions of milliseconds here, but at high rpms, things are happening at fractions of milliseconds. <br /><br />Thanks for your input!
