The OMC/BRP Service Manual calls for the QL86C if you also look up the E35QLED or a E25KLED at Marine Engine you will see that the triple use the QL86 spark plugs. Item number 33.
In the motor now I have QL86C but Iam going with NGK BR6HS thats what the guy at NAPA said the match from champion to NGK was THANKS again for the info guys.hope its right.
no big one I just thought I would try the NGK but I will get a set of champion plugs to and keep in the boat two dont hurt to have a extra set.Thanks hidef
