Spark plug gap
chas451
Just installed new Champion L77JC4 spark plugs in a 1988 Johnson 70 HP. Champion calls for the gap to be set at .030" but the Clymer manual says to use .040". I understand the wider gap will foul less when trolling and the smaller gap best for high speed. Does that mean that using .035" gap would be the best all around setting? Anyone have any ideas on this?<br /><br />Thanks, Chas
bubbakat
Re: Spark plug gap
I run mine at 40 but you could set them at 35 I don't see any prob. with it.<br />One way to find out is run it a day with each of the settings and see what suits you.
rickdb1boat
Re: Spark plug gap
And you should be using QL77JC4 suppression plugs with that motor. Not just L77JC4.
