Re: Spark plug gaskets
Rocky, although GM specifies 100,000 miles on plug changes I can assure you going that long is a recipe for issues. First is the constant heat/cool cycles can cause plug seizure in the the head. Second, is an equally troublesome problem. I've seen the rounded seal area of the plug (that area where the top of the metal plug shell meets the porcelain) weakened to the point where the entire electrode and porcelain blows out of the plug. The next issue is when trying to remove seized plugs is that the thread area of the plug breaks off the hex part of the shell. It happens a lot and not just on GM cars. While the plugs look great at 100,000 miles, operating conditions and the plug construction may not be up to the task.
Hi Silvertip!
I am well acquainted with plugs seizing in heads...used to pull wrenches on Mercury when we called them 'Kiekhaefers', and they only had a 90 day warranty. Actually, there is an amusing story about the short warranty period...tells you volumes about how Carl Kiekhaefer felt he had the superior product.
I treat the threads on my plugs, and actually use a torque wrench to install them. I will never be posting here about
'my plug has broken off, and what can I do now???'
I have no problem with those that change their plugs annually, and for many that may be the safest thing to do. I was addressing the question about the crush washers that the OP referred to...and I stand by the 'fact' that they are designed for one time use only. I also went on to say that most don't worry about that fact, and that seems to be the prevailing thought. My plugs don't get reused if pulled (my 454SS truck is an exception, since I am pretty sure that they have tapered seat plugs).
In short: I agree that the average boater might be better off replacing their plugs every several years...if only to prevent plug seizure. But I also say that the average boater probably doesn't pay any attention to treating the threads...using a torque wrench...and not reusing the crush washers.
I do...and I suspect that you do also!
Happy boating!
