went to change plugs on my 1988 evinrude 100 hp w100wtlm at napa they looked them up and gave me the champion QL16V spark plugs when I went to change them I found champion L78V plugs installed when you compare the two plugs the QL16V is a slight bit longer on the electrode end could someone please check to see what plugs are correct for my engine. I am worried about piston clearance. the champion site says QL16v is correct Thanks Randy
