bleedblue94
- Joined
- Oct 11, 2010
- 272
1983 175 johnson. I have had ngk buhxw-1 plugs in it for awhile. These are the ngk surface gap eqivanlant to the champ qul77v plugs. They have fouled up after a year of use. The shop manual calls for champ qul77v or ul77v (both buhxw-1 equivalants), however in doing reseach I have found many suggest this plug for more WOT use, and instead suggest ql77jc4 for more low rpm use. Is this kind of hearsay info correct? The current ngks also seem to always have a wet and black appearance as if there isn't a complete burn. Thanks for the input
