watergecko
- Joined
- Dec 1, 2010
- 111
Can someone please explain the difference between ngk and champion plugs. I know the champions are the oem recomended, but in my particular motor, ive noticed in runs better with the ngk's. Is it the plug design or did i luck out with a more appropriate heat range plug? I have a 1989 johnson 25, on a 14ft aluminum fishing boat. I get 31mph per gps at wot. I use it either wide open or at no wake with nothing in between. 70/30 split on usage. Plugs were champion ql77jc4 and were replaced with ngk br7hs.
