Starting from top cylinder to bottom (left to right) these are the spark plugs I ran at break in approx 3.5 hrs is this normal for top to be more black then bottom?? Thanks for the help
What does break in refer to? Is this a new engine or did you just rebuild it?
In general, the rings on #1 will begin to plateau the cylinders and seal first. This is mainly due to heat. #3 will often run colder and wet at idle but will come around after about 10 hours or when your finally running at 50:1 mix.
