Good morning,
Yesterday while putting my outboard to bed for the winter I noticed something strange about the spark plugs. I have a 1978 Mercury 402 (40HP) outboard.
The past 3 years (too busy for boating) it has only been run in the driveway. Mostly while being winterized. I had put new plugs in it back in 2004.
When I removed the lower spark plug to spray fogging oil into the motor, I noticed that the plug was still nice and shiny on the bottom. The top plug was discolored.
I assume that means I am not getting spark to the bottom plug. Correct? The last time I actually used the boat was in 2004. At that time it did not run right. No power, rough running, barely made it back to the dock.
Any suggestions on what I should check next Spring?
Thank you in advance.
Ed
Ed
