Spark plug wire set for 7.4L Bravo
jet_pilot
Brand new to the forum and pretty new to boating over all. I have a 91' SeaRay 270Da with a 91 rebuilt 7.4L V8 and a Bravo 2 leg. I was going to replace the spark plug wires and came across a deal on a set from Sierra, part number 18-8802 which I bought . In looking around it seems to me that I have a choice 18-8802 ( the ones I bought) or 18-8804 for thunderbolt ignition... Whats the difference? What If I got the wrong ones? Does it matter?
Will get some pics of the boat and engine up in a week or so for future questions, I am sure I will have lots.
Thanks for the help!!
B
HT32BSX115
Re: Spark plug wire set for 7.4L Bravo
B
Howdy,
Welcome to iBoats!!
The Thunderbolt ignition is a high energy ignition system compared to a points/coil type system. higher voltage probably.....
I believe yours is a coil type with an electronic (non-points) type system.....possibly similar to a Pertronix system.
Since Mercruiser uses serial number ranges to determine parts requirements, it's helpful if you post those.
What kind of Jet do you pilot?
Regards,
Rick
jet_pilot
Thanks Rick, here are the serial numbers from the engine OD611781, outdrive OD634523 and Part numbers for the distributor cap 805759T-2 (replaced in 96') and rotor assembly 13524T-1 (replaced 96').
Fly a LearJet 31A
Thanks,
Barret
Ayuh,... Welcome Aboard,...
I donno what you bought, but a 91 is possibly a T-Bolt IV, or more likely T-Bolt V igntion...
HT32BSX115
Yeah. It might be a IV.
OD611781 according to Doug Russell refers to the diagram below.
0D603118 THRU 0F800699
Is the above a IV? Mine is a V
According to your serial number it could be a TB IV or V. you'll have to check the link below.
Your serial number according to the following link could be a 92 model.
http://www.dougrussell.com/partscat...N. V) GM 454 V-8 1992-1996&index=1621
Fly a LearJet 31A
Cool jet. keep that oxy mask close above 410!!!:eek:
Cheers,
Rick
jet_pilot
I know I cringe above 410, I have been as high as 470 never light enough to see her reach the 510 advertised...
Anyway is it a problem if I put on spark plug wires that were intended for a non thunderbolt ignition?
Barret
HT32BSX115
Barret
I had a T-38 to 470 once. Go above 500 and the USAF would consider you an Astronaut!! I actually thought I saw curvature of the earth! I also thought the sky seemed darker in the middle of the day! Now I don't ever go above 410:rolleyes: That's scary enough!
Those plug wires will probably be ok. Most wiring sets nowadays will handle all the newer electronic high energy systems.
If you could take them back, I would get the "right" ones though.
In the worst case, you could have arc-through if the insulation wasn't good enough to handle the higher voltage. That would be a problem.
Ayuh,... My Guess is, the cap ends might be Innys, instead of Outys...
I kinda doubt there's much difference in the actual cables...
jet_pilot
Thanks guys, I will give them a try one at a time see if the cylinders are still working fine since I can't take them back. If it works great if not not a big loss.
And yah the sky is definately darker more of a black blue at 470!
Barret
