The Force power
- Joined
- Feb 3, 2019
- 2,351
#1 switch box / replaced ALL wire terminals/cleaned pins & sockets from all plug-ins.
Compression #1 -135 PSI
#2 -140
#3- 140
Motor not running in High Idle will die if tried, will start shaking violently when running in idle randomly & quit
Fuel pump Pressure is good about 2-3 psi at cranking & fuel filter full of fuel & not dropping when running idle
after 5 min. run time or so, pulled plugs;
#1 Clean & dry
#2 Clean & wet
#3 Black & dry--Running too rich? when Mixture needle set at 1 turn out OR Re-circulation vents/hoses plugged
What am I missing/ doing wrong?
#2 -140
#3- 140
#1 Clean & dry
#2 Clean & wet
