Re: Spark plugs for Johnson 115
If you are using the more expensive "Z" NGK plug with the correct heat range, you are OK. But if you are using the "R" or non R NGK, you should change to the correct Champion number, QL82C gapped to .030". Back before 1996, OMC recommended the QL77JC4, but changed the spec to a more foul-resistant plug.<br /><br />The Z in NGK and the Q in Champion indicate a suppressor type of sparkplug that the OMC ignition system needs. This is completely different from a resistor plug as it "retards" the AC current, but allows the DC current to pass thru unimpeded for the spark duration.
